DRAFT help
Fitting Linear Models > Mixed Models > Statistical Details for the Mixed Model Personality > Statistical Details for the Convergence Score Test
Publication date: 09/20/2024
Image shown hereStatistical Details for the Convergence Score Test
In the Mixed Model report, the convergence failure warning shows the score test for the following hypothesis: that the unknown maximum likelihood estimate (MLE) is consistent with the parameter given in the final iteration of the model-fitting algorithm. This hypothesis test is possible because the relative gradient criterion is algebraically equivalent to the score test statistic. Remarkably, the score test does not require knowledge of the true MLE.
Image shown hereScore Test
Consider first the case of a single parameter, θ. Let l be the log-likelihood function for θ and let x be the data. The score is the derivative of the log-likelihood function with respect to θ:
Equation shown here
The observed information is:
Equation shown here
The statistic for the score test of H0: θ = θ0 is:
Equation shown here
This statistic has an asymptotic Chi-square distribution with 1 degree of freedom under the null hypothesis.
The score test can be generalized to multiple parameters. Consider the vector of parameters θ. Then the test statistic for the score test of H0: θ = θ0 is:
Equation shown here
where
Equation shown here
and
Equation shown here
and U denotes the transpose of the matrix U.
The test statistic is asymptotically Chi-square distribution with k degrees of freedom. Here k is the number of unbounded parameters.
Image shown hereRelative Gradient
The convergence criterion for the Mixed Model fitting procedure is based on the relative gradient gH1g. Here, g(θ) = U(θ) is the gradient of the log-likelihood function and H(θ) = I(θ) is its Hessian.
Let θ0 be the value of θ where the algorithm terminates. Note that the relative gradient evaluated at θ0 is the score test statistic. A p-value is calculated using a Chi-square distribution with k degrees of freedom. This p-value gives an indication of whether the value of the unknown MLE is consistent with θ0. The number of unbounded parameters listed in the Random Effects Covariance Parameter Estimates report equals k.
