DRAFT help
Basic Analysis > Bivariate Analysis > Statistical Details for the Bivariate Platform > Statistical Details for the Lack of Fit Report
Publication date: 09/20/2024
This section contains details for the Lack of Fit report in the Bivariate platform.
Pure Error DF
For the Pure Error DF, consider the cases where more than one observation has the same value for height. In general, if there are g groups having multiple rows with identical values for each effect, the pooled DF, denoted DFp, is defined as follows:
Equation shown here
where ni is the number of observations in the ith group.
Pure Error SS
For the Pure Error SS, in general, if there are g groups having multiple rows with the same x value, the pooled SS, denoted SSp, is defined as follows:
Equation shown here
where SSi is the sum of squares for the ith group corrected for its mean.
Max RSq
Because Pure Error is invariant to the form of the model and is the minimum possible variance, Max RSq is calculated as follows:
Equation shown here
