DRAFT help
Predictive and Specialized Modeling > Response Screening > Statistical Details for the Response Screening Platform
Publication date: 09/20/2024
All of the Response Screening plots involve p-values for tests conducted using the False Discovery Rate technique described in Benjamini and Hochberg (1995). See also Westfall et al. (2011). This method assumes that the p-values are independent and uniformly distributed.
The Response Screening platform uses the following procedure to control the false discovery rate at level α:
1. Conduct the m hypothesis tests of interest to obtain p-values p1, p2,..., pm.
2. Rank the p-values from smallest to largest. Denote these by p(1)p(2) ≤ ... ≤ p(m).
3. Find the largest p-value for which p(i) ≤ (i/m)α. Suppose this first p-value is the kth largest, p(k).
4. Reject the k hypotheses associated with p-values less than or equal to p(k).
This procedure ensures that the false discovery rate does not exceed α.
The p-values adjusted for the false discovery rate, denoted p(i), FDR, are computed as follows:
Equation shown here
If a hypothesis has an FDR-adjusted p-value that falls below α, then it is rejected by the procedure.
