DRAFT help
Basic Analysis > Distributions > Statistical Details for the Distribution Platform > Statistical Details for the Standard Deviation Test
Publication date: 09/20/2024
The test statistic in the standard deviation test in the Distribution platform is computed as follows:
Equation shown here
The test statistic is distributed as a chi-square variable with n - 1 degrees of freedom when the population is normal.
The Min PValue is the p-value of the two-tailed test, and is calculated as follows:
2*min(p1,p2)
where p1 is the lower one-tail p-value and p2 is the upper one-tail p-value.
