DRAFT help
Publication date: 09/20/2024
String SQL Functions
Function
Native SQLite
Description
HEX( binary )
Yes
SQLite built-in function that converts a BLOB to a string of hexadecimal characters. Useful when paired with the RANDOMBLOB() function.
JLEFT( string, len, <pad> )
Like the JSL Left() function. Returns len characters from the beginning of string. If pad is specified and fewer than len characters are present in string, the result is padded with pad out to length len.
JRIGHT( string, len, <pad> )
Like the JSL Right() function. Returns len characters from the end of string. If pad is specified and fewer than len characters are present in string, the result is padded with pad at the front out to length len.
LENGTH( string )
Yes
SQLite equivalent of the ANSI standard CHAR_LENGTH() function. Returns the length of its string argument in characters.
LOCATE( string1, string2 )
POSITION( string1, string2 )
Returns the (1-based) starting position of string1 within string2, returning 0 if string1 is not found within string2.
LOWER( string )
Returns a copy of string with all uppercase characters converted to lowercase.
LTRIM( string, <trimchars> )
Yes
Trims any characters contained in trimchars from the beginning of string and returns the result. If trimchars is omitted, spaces are trimmed.
PRINTF( format, <arg1, ..., argN> )
Yes
Allows constructing strings using placeholders and arguments. See the SQLite Online documentation at https://www.sqlite.org/lang.html.
REPLACE( string, find, replace )
Yes
Replaces all instances of find in string with replace and returns the result. If replace is numeric, it is converted to a string.
REVERSE( string )
Returns a copy of string with the order of the characters reversed.
RTRIM( string, <trimchars> )
Yes
Trims any characters contained in trimchars from the end of string and returns the result. If trimchars is omitted, spaces are trimmed.
SPACE( length )
Returns a string consisting of length space characters.
SUBSTR( string, start, <length> )
Yes
Returns the substring of string starting at start (1-based) that is length characters long. If length is omitted, the substring starting at start and continuing to the end of string is returned.
UPPER( string )
Returns a copy of string with all lowercase characters converted to uppercase.
