DRAFT help
Predictive and Specialized Modeling > Support Vector Machines
Publication date: 09/20/2024
Image shown hereSupport Vector Machines
Predict Response Categories Using Support Vectors
The Support Vector Machines platform is available only in JMP Pro.
The Support Vector Machines (SVM) platform provides a machine learning tool for both nonlinear regression and classification. The SVM algorithm is a supervised learning algorithm that uses the training data to build a model to predict or classify new observations.
If you have a categorical response, you can visualize the model classification in the Response Profile Plot. The SVM platform also provides misclassification rates, confusion matrices, and ROC and Lift curves to help you determine how well your model fits the data. If you have a continuous response, fit statistics and actual by predicted plots are used to determine how well the model fits the data.
Figure 9.1 Response Profile PlotĀ
Contents
Overview of Support Vector Machines
Example of Support Vector Machines
Launch the Support Vector Machines Platform
Model Launch Control Panel
The Support Vector Machine Report
Model Comparison Report
Support Vector Machine Model Report
Support Vector Machines Platform Options
Support Vector Machine Model Report Options
Additional Example of Support Vector Machines
