DRAFT help
Publication date: 09/20/2024
Survival Analysis
Analyze Survival Time Data
Survival data contain duration times until the occurrence of a specific event and are sometimes referred to as event-time response data. The event is usually failure, such as the failure of an engine or death of a patient. If the event does not occur before the end of a study for an observation, the observation is said to be censored.
The Survival platform fits a single Y that represents time to event (or time to failure). Use the Survival platform to examine the distribution of the failure times.
Tip: To fit explanatory models, use the Fit Parametric Survival platform or the Fit Proportional Hazards platform.
Figure 14.1 Example of a Survival PlotĀ
Contents
Overview of the Survival Analysis Platform
Example of Survival Analysis
Launch the Survival Platform
The Survival Plot
Survival Platform Options
Exponential, Weibull, and Lognormal Plots and Fits
Fitted Distribution Plots
Competing Causes
Additional Examples of the Survival Platform
Example of Plotting Failures instead of Survival Events
Example of Competing Causes
Example of Interval Censoring
Statistical Details for Survival Analysis
