DRAFT help
Genetics > Marker Statistics > The Marker Statistics Report and Options
Publication date: 09/20/2024
The Marker Statistics report enables you to explore several properties of all the biallelic markers in a data set. This process calculates various single marker measures, as well as various measurements of linkage disequilibrium.
The Marker Statistics red triangle menu contains the following options:
Levels Table
Select this option to view the Levels Table. The Levels table indicates the number of genotypes observed for each marker.
Counts Table
Select this option to view the Counts Table. The Counts table indicates the number of individuals exhibiting each genotype for each marker.
Result Table
Select this option to view the Result Table.
PValue Plot
Select this option to view the Hardy-Weinberg Equilibrium FDR Logworth Plot.
LD Decay Plot
Select this option to view the LD Decay Plot.
Note: This option is available when one or more With Markers are specified.
Save Result Table
Use this option to save the Result table as a JMP table.
Save Proportion of Missing Markers
Use this option to add a column to the original data table containing the proportion of missing markers in each row.
Select Where
Use this option to subset the Result Table based on specified criteria.
Select Columns
Select row in the Result Table and then use this option to select the corresponding columns in the original data table.
Recode Marker
Recodes all the selected marker columns in the original data table by switching the major and minor alleles.
Select and Recode Marker
Opens a new new dialog window enabling the user to enter a valid selection criterion for the markers that will be recoded. Upon entering the selection criterion, click OK and the selected markers will have their recode system swapped (minor to major or vice-versa).
