DRAFT help
Publication date: 09/20/2024
The Stepwise Report
The Stepwise Fit report contains platform options, a control panel, and reports that contain the current estimates and the step history.
Platform options
The Stepwise Fit red triangle menu contains options that affect all of the variables. See Stepwise Platform Options.
Stepwise Regression Control
Controls that limit regressor effect probabilities, determine the method of selecting effects, start or stop the selection process, and create a model. See Stepwise Regression Control Panel.
Current Estimates
A report that enables you to add, remove, and lock in model effects. See Current Estimates Report.
Step History
A report that records the effect of adding a term to the model. See Step History Report.
