DRAFT help
Scripting Guide > JSL Building Blocks > Rules for Name Resolution > Troubleshoot Variables and Keywords
Publication date: 09/20/2024
In JSL, name resolution errors can also occur when a variable and unquoted keyword have the same name. For example, one argument for <<Preselect Role() is “Y”. Quote this argument if your script also uses Y as a variable.
