DRAFT help
Publication date: 09/20/2024
Univariate Patterns Report Options
Each Univariate Patterns red triangle menu contains the following options:
Select Most Duplicated
Selects the observations in the data table that correspond to the values in the Most Duplicated Values table.
Select Longest Runs
Selects the observations in the data table that correspond to the values in the Longest Runs table.
Select Longest Duplicate Sequences
Selects the observations in the data table that correspond to the values in the Longest Duplicate Sequences table.
Select by Formatted Width
Selects the observations in the data table that correspond to the values in the Formatted Widths table that have the user-specified overall width.
Select by Decimal Width
Selects the observations in the data table that correspond to the values in the Formatted Widths that have the user-specified decimal width.
Select by Fraction Length
Selects the observations in the data table that correspond to the values in the Fraction Length table that have the user-specified fraction length.
Select by Leading Digit
Selects the observations in the data table that correspond to the values in the Leading and Trailing Digits table that have the user-specified leading digit.
