DRAFT help
Publication date: 09/20/2024
Use Matrices
The matrix concatenation operators, || and |/, add columns or rows to a matrix dynamically. However, the script runs faster if you define a matrix in a static fashion instead.
// faster example
t1 = Tick Seconds();
A = J( 10, 10000, . );
For( i = 1, i <= 10000, i++,
	a2 = J( 10, 1, Random Gamma( 1, 1 ) );
// define a2 to be a 10 by 1 vector of random gamma values.
       A[0, i] = a2;
/* populate the ith column of the matrix A to have the
values in a2. The first argument, 0, means "all rows". */
t2 = Tick Seconds();
Show( t2 - t1 );
t2 - t1 = 0.0166666666627862;
// slower example
t3 = Tick Seconds();
B = J( 10, 0, . );
	B = B || a2;
t4 = Tick Seconds();
Show( t4 - t3 );
t4 - t3 = 3.1333333333605;
If you know the size of a matrix that you're going to need, it’s typically better to allocate the matrix in its entirety first and then populate it. In the example below, the J() function is doing the allocation of the 100000x1 matrix all at the same time.
Delete Symbols( a1, a2 );
// faster example
a1 = J( 100000, 1, Random Uniform() );
Show( t2 - t1 );
Delete Symbols( a1 );
t2 - t1 = 0;
// slower example
a2 = J( 0, 0 );
For( i = 1, i <= 100000, i++,
	a2 |/= Random Uniform()
Show( t4 - t3 );
t4 - t3 = 5.05000000004657;
Use matrices rather than a data table to store numbers.
