DRAFT help
Design of Experiments Guide > Choice Designs > Statistical Details for Choice Designs > Utility-Neutral and Local D-Optimal Designs
Publication date: 09/20/2024
You can use the Choice Design platform to generate a utility-neutral design by setting prior means to 0. In a utility-neutral design, all choices within a choice set are equally probable. See Huber and Zwerina (1996).
You can also generate a local D-optimal design. The local design takes into account the prior of the mean, but does not include any information from a prior covariance matrix. See Huber and Zwerina (1996).
