DRAFT help
Publication date: 09/20/2024
Work with Watch Variables
JMP preserves Watch variables across sessions. So when you close and reopen JMP, the Watch variables are still listed on the Watch tab.
Create a Watch
On the Watch tab, click Image shown here and enter the value in the window.
In the Debugger, right-click the line that you want to watch, select Add Watch, and then enter the variable name in the window.
In the Debugger, place the cursor in or next to a variable name (or select the variable name), right-click, and select Add Watch.
On the Watch tab, enter the variable in an empty Variable field.
Modify a Watch
Do one of the following on the Watch tab to enter a new value:
Select the watch and click Image shown here.
Click in the Variable field and enter a new value.
Delete Watches
Do one of the following on the Watch tab to delete watches:
Select the watch and then click Image shown here.
Click Image shown here to remove all watches.
