JSL Syntax Reference > JSL Functions > Comment Functions
发布日期: 04/13/2021
Comment Functions
// comment
Description
Comments to end of line.
Notes
Everything after the // is ignored when running the script.
/* comment */
Description
A comment that can appear in the middle of a line of script.
Notes
Anything between the beginning tag /* and the end tag */ is ignored when running the script. This comment style can be used almost anywhere, even inside lists of arguments. If you place a comment inside a double-quoted string, the comment is treated merely as part of the string and not a comment. You cannot place comments in the middle of operators.
Examples
+/*comment*/=
:/*comment*/name
are invalid and produce errors. The first comment interrupts += and the second interrupts :name.
sums = {(a+b /*comment*/), /*comment*/ (c^2)}
is valid JSL; the comments are both ignored.
Description
If placed on the first line of a script, this comment line causes the script to be run when opened in JMP without opening into the script editor window.
Notes
You can over-ride this comment when opening the file. Select File > Open. Hold the Ctrl key while you select the JSL file and click Open. Or right-click the file in the Home Window Recent Files list and select Edit Script. The script opens into a script window instead of being executed.
/*debug step*/
/*debug run*/
Description
If placed on the first line of a script, the script is opened into the debugger when it is run.
Notes
All letters must be lower case. There must be one space between debug and step or run, and there must be no other spaces present. Only one of these lines can be used, and it must be the first line of the script; a first line that is blank followed by this comment negates the debug command.
