Scripting Guide > Efficient Scripts
发布日期: 04/13/2021
Efficient Scripts
Tips for Writing Scripts That Run Faster
This appendix provides ideas for writing scripts that run faster and more efficiently. For example, it is possible to control how much time is allocated to finding an optimal design. You can collapse outlines in a report that are not necessary. Or you can write static matrices, which is faster than developing them dynamically.
Contents
Using Matrices
Design of Experiments
Scripting Data Tables
Scripting Graphs and Display Boxes
Scripting Numbers, Strings, Arrays, and Lists
Programming Tips
Troubleshooting
