Scripting Guide > Introduction > Help with Learning JSL
发布日期: 04/13/2021
There are several places within JMP to get help with writing or understanding a JSL script.
The Scripting Guide
The Scripting Guide begins with basic information (such as terminology and syntax) for JMP users who are not familiar with the scripting language. The Scripting Guide then progresses to more advanced information.
Chapters 2 through 4
Includes information about learning JSL, producing basic scripts, and introduces you to the JSL scripting environment.
Chapters 5 through 8
Introduces the building blocks of the language; working with basic data types, such as numbers and strings; writings lists, matrices, and associate arrays; namespaces; and the fundamentals of programming in JSL.
Chapters 9 through 13
Covers using JSL with objects in JMP, such as data tables, platforms, windows, and graphics.
Chapter 14
Describes how to write scripts that work with external programs, such as SAS, R, and Microsoft Excel.
Chapter 15
Introduces creating JMP applications in Application Builder, a drag-and-drop environment for visually designing windows with buttons, lists, graphs, and other objects. The chapter also describes how to use Add-In Builder to compile scripts into one easily shared file.
Chapter 16
Contains a collection of recipes, or script examples, that you can copy and modify for your own use.
Appendices A, B, C, and D
Provides information about compatibility issues with the previous version of JMP, provides tips for writing more efficient scripts, gives information about references, and defines JSL concepts and terminology.
