Scripting Guide > Extending JMP > Work with Python > JMP-to-Python Interfaces
发布日期: 04/13/2021
JMP provides the interfaces to access Python that are described in the following sections. The basic execution model is to first initialize the Python connection, perform the required Python operations, and then terminate the Python connection. In most cases, these functions return 0 if the Python operation was successful or an error code if it was not. If the Python operation is not successful, a message is written to the log. The single exception to this is Python Get(), which returns a value.
Python JSL-Scriptable Object Interfaces
The Python interfaces are also scriptable using a Python connection object. A scriptable Python connection object can be obtained using the Python Connect() function.
// return a Python connection scriptable object
PythonConnection = Python Connect();
// return 1 if a Python connection is active. Otherwise, returns 0.
x = PythonConnection << Is Connected;
Show( x );
PythonConnection << Disconnect;
x = 1;
0
