发布日期: 04/13/2021
List Functions
As List(matrix)
Description
Converts a matrix into a list. Multi-column matrices are converted to a list of row lists.
Returns
A list.
Argument
matrix
Any matrix.
Concat Items({string1, string2, ...}, <delimiter>})
Description
Converts a list of string expressions into one string, with each item separated by a delimiter. The delimiter is a blank, if unspecified.
Returns
The concatenated string.
Arguments
string
any string
delimiter
an optional string that is placed between each item. The delimiter can be more than one character long.
Example
str1 = "one";
str2 = "two";
str3 = "three";
comb = Concat Items({str1, str2, str3});
"one two three"
comb = Concat Items({str1, str2, str3}, " : ");
"one : two : three"
del = ",";
comb = Concat Items({str1, str2, str3}, del);
"one,two,three"
Eval List({list})
Description
Evaluates expressions inside list.
Returns
A list of the evaluated expressions.
Arguments
list
A list of valid JSL expressions.
Insert(source, item, <position>)
Insert(source, key, value)
Description
Inserts a new item into the source at the given position. If position is not given, item is added to the end.
For an associative array: Adds the key into the source associative array and assigns value to it. If the key exists in source already, its value is overwritten with the new value.
Arguments
source
A string, list, expression, or associative array.
item or key
Any value to be placed within source. For an associative array, key might or might not be present in source.
position
Optional numeric value that specifies the position in source to place the item into.
value
A value to assign to the key.
Insert Into(source, item, <position>)
Insert Into(source, key, value)
Description
Inserts a new item into the source at the given position in place. The source must be an L-value.
Arguments
source
A variable that contains a string, list, display box, expression, or associative array.
item or key
position
value
Is List(x)
Description
Returns 1 if the evaluated argument is a list, or 0 otherwise.
Items(string, <Delimiter>, <Include Boundary Delimiters(Boolean)>)
Description
Returns a list of (possibly empty) sub-strings separated by exactly one of any of the characters specified in the delimiter argument.
Arguments
string
The string being evaluated.
Delimiter
(Optional) The character used as a boundary. If delimiter is absent, an ASCII space is used. If delimiter is the empty string, each character is treated as a separate word. If delimiter is an empty string, each character is treated as a spate word.
(Optional) Includes the delimiters in the returned string.
Example
Items( "http://www.jmp.com", ":/." );
{"http", "", "", "www", "jmp", "com"}
Items(",toy,", ",");
{"toy"}
Items(",toy,", ",", Include Boundary Delimiters( 1 ));
{"", "toy", ""}
// There is no text between the boundary (the beginning of the string) and the comma delimiter, so you get an empty string. The same priniciple applies to the delimiter at the end of the string.
List(a, b, c, ...)
{a, b, c, ...}
Description
Constructs a list from a set of items.
N Items(source)
Description
Determines the number of elements in the source specified.
Returns
For a list or display box, the number of items in the list or display box is returned. For an associative array, the number of keys is returned. For a matrix, the number of elements in the matrix is returned. For a namespace, the number of functions and variables in the namespace is returned. For a class object, the number of methods, functions, and variables is returned.
Arguments
source
A list, associative array, matrix, display box, or namespace.
Remove(source, position, <n>)
Remove(source, {items})
Remove(source, key)
Description
Deletes the n item(s), starting from the indicated position. If n is omitted, the item at position is deleted. If position and n are omitted, the item at the end is removed. For an associative array: Deletes the key and its value.
Returns
A copy of the source with the items deleted.
Arguments
source
position or key
An integer (or list of integers) that points to a specific item (or items) in the list or expression.
n
(Optional) An integer that specifies how many items to remove.
Remove From(source, position, <n>)
Remove From(source, key)
Description
Deletes the n item(s) in place, starting from the indicated position. If n is omitted, the item at position is deleted. If position and n are omitted, the item at the end is removed. For an associative array: Deletes the key and its value. The source must be an L-value.
Returns
The original source with the items deleted.
Arguments
source
A string, list, expression, display box, or associative array.
position or key
n
Reverse(source)
Description
Reverse order of elements or terms in the source.
Argument
source
A string, list, or expression.
Reverse Into(source)
Description
Reverses the order of elements or terms in source in place.
Argument
source
A string, list, display box, or expression.
Shift(source, <n>)
Description
Shifts an item or n items from the front to the back of the source.
Arguments
source
n
(Optional) An integer that specifies the number of items to shift. Positive values shift items from the beginning of the source to the end. Negative values shift items from the end of the source to the beginning. The default value is 1.
Shift Into(source, <n>)
Description
Shifts items in place.
Arguments
source
n
Sort List({list }|expr)
Description
Sort the elements or terms of list or expr.
Sort List Into({list }|expr)
Description
Sort the elements or terms of list or expr in place.
Substitute("string", "substring", "replacementString", ...)
Substitute({list }, listItem, replacementItem, ...)
Substitute(Expr(sourceExpr), Expr(findExpr), Expr(replacementExpr), ...)
Description
This is a search and replace function. It searches for a specific portion (second argument) of the source (first argument), and replaces it (third argument).
If a string, finds all matches to substring in the source string, and replaces them with the replacementString.
If a list, finds all matches to listItem in the source list, and replaces them with the replacementItem.
If an expression, finds all matches to the findExpr in the sourceExpr, and replaces them with the replacementExpr. Note that all expressions must be enclosed within an Expr() function.
Arguments
string, list, sourceExpr
A string, list, or expression in which to perform the substitution.
substring, listItem, findExpr
A string, list item, or expression to be found in the source string, list, or expression.
replacementString, replacementItem, replacementExpr
A string, list item, or expression to replace the found string, list item, or expression.
Substitute Into("string", substring, replacementString, ...)
Substitute Into(list, listItem, replacementItem, ...)
Substitute Into(Expr(sourceExpr), Expr(findExpr), Expr(replacementExpr), ...)
Description
This is a search and replace function, identical to Substitute() except in place. It searches for a specific portion (second argument) of the source (first argument), and replaces it (third argument). The first argument must be an L-value.
Arguments
Words("string", <delimiter>)
Description
Extracts the words from string according to the delimiters given. The default delimiter is ASCII whitespace. If you include a second argument, any and all characters in that argument are considered delimiters. If delim is an empty string, each character is treated as a separate word.
Examples
Words( "the quick brown fox" );
{"the","quick","brown","fox"}
Words( "Doe, Jane P.",", ." );
{"Doe","Jane","P"}
