Scripting Guide > Data Structures > Matrices > Matrices and Data Tables
发布日期: 04/13/2021
You can move information between a matrix and a JMP data table. You can use matrix algebra to perform calculations on numbers that are stored in JMP data tables, and you can save the results back to JMP data tables.
Move Data into a Matrix from a Data Table
These sections describe how to move data from a data table into a matrix.
Move All Numeric Values
The Get As Matrix() function generates a matrix containing all of the numeric values in a data table or column:
A = dt << Get As Matrix;
[12 59 95,
12 61 123,
12 55 74, ...]
col = Column( "Height" );
A = col << Get As Matrix;
[59, 61, 55, 66, 52, ...]
Move All Numeric Values and Character Columns
The Get All Columns As Matrix() function returns the values from all columns of the data table in a matrix, including character columns. Character columns are numbered according to the alphanumeric order, starting at 1.
A = dt << Get All Columns As Matrix;
[21 12 1 59 95,
28 12 1 61 123, ...]
Move Only Certain Columns
To get certain columns of a data table, use column list arguments (names or characters).
x = dt << Get As Matrix( {"height", "weight"} );
or
x = dt << Get As Matrix( {height, weight} );
[59 95, 61 123, 55 74, ...]
Currently Selected Rows
To get a matrix of the currently selected row numbers in the data table:
dt << Get Selected Rows;
Note: If no rows are selected, the output is an empty matrix.
Find Rows Where
To see a matrix of row numbers where the expression is true:
dt << Get Rows Where( expression );
For example, the following script returns the row numbers where the sex is male (M):
A = dt << Get Rows Where( Sex == "M" );
[6, 7, 8, 12, 13, 14, ...]
Move Data into a Data Table from a Matrix
This section describes how to move data from a matrix into a data table.
Move a Column Vector
The Set Values() function copies values from a column vector into an existing data table column:
col << Set Values( x );
col is a reference to the data table column, and x is a column vector.
For example, the following script creates a new column called test and copies the values of vector x into the test column:
dt << New Column( "test" );
col = Column( "test" );
x = 1::40;
Move All Matrix Values
The Set Matrix() function copies values from a matrix into an existing data table, making new rows and new columns as needed to store the values of the matrix. The new columns are named Col1, Col2, and so on.
dt = New Table( "B" );
dt << Set Matrix([1 2 3 4 5, 6 7 8 9 10]);
This script creates a new data table called B containing two rows and five columns.
To create a new data table from a matrix argument, use the As Table(matrix) command. The columns are named Col1, Col2, and so on. For example, the following script creates a new data table containing the values of A:
A = [1 2 3, 4 5 6, 7 8 9, 10 11 12];
dt = As Table( A );
