发布日期: 04/13/2021
Number Edit Box
Number Edit Box<<Set Format(<width>, <decimal places>, <"Use Thousands Separator">|<other options>)
Description
Sets the column format.
Arguments
A number of other formats can be set on number edit boxes. See Number Col Box<<Set Format(<width>|<width, decimal places>, <"Use Thousands Separator">) for more information about the syntax. 数值格式 in Using JMP also describes the arguments.
