JSL Syntax Reference > JSL Functions > R Integration Functions
发布日期: 04/13/2021
R Connect( <named_arguments> )
Description
Returns the current R connection object. If there is no connection to R, it intializes the R integration interfaces and returns an active R integration interface connection as a scriptable object.
Returns
R scriptable object.
Arguments
Echo(Boolean)
(Optional) Sends all source lines to the JMP log. This option is global. The default value is true.
R Control(Interrupt|Async(Boolean)|Echo(Boolean))
Description
Changes the control options for R.
R Execute( { list of inputs }, { list of outputs }, "rCode", <named_arguments> )
Description
Submit the specified R code to the active global R connection given a list of inputs. On completion, the outputs are returned into the specified list.
Returns
0 if successful; nonzero otherwise.
Arguments
{ list of inputs }
A list of JMP variable names to be sent to R as inputs.
{ list of outputs }
A list of JMP variable names to contain the outputs returned from R.
rCode
A quoted string that contains the R code to submit.
Expand(Boolean)
An optional, Boolean, named argument. Performs an Eval Insert() on the R code before submitting to R.
Echo(Boolean)
An optional, Boolean, named argument. Sends all source lines to the JMP log. This option is global. The default value is true.
Example
Send the JMP variables x and y to R, execute the R statement z <- x * y, and then get the R variable z and return it to JMP.
x = [1 2 3];
y = [4 5 6];
rc = R Execute( {x, y}, {z}, "z <- x * y" );
R Get( variable_name )
Description
Gets the named variable from R to JMP.
Returns
The value of the named variable.
Argument
name
Required. The name of an R variable whose value to return to JMP.
Example
Assume that a matrix named qbx and a data frame named df are present in your R connection.
// get the R variable qbx and placed it into a JMP variable qbx
qbx = R Get( qbx );
// get the R variable df and placed it into a JMP data table referenced by df
df = R Get( df );
R Get Graphics( "format" )
Description
Gets the last graphics object written to the R graph display window in the specified format.
Returns
A JMP picture object.
Argument
format
Required. Specifies the graphics format to be used. The valid formats are "png", "bmp", "jpeg", "jpg", "tiff", and "tif".
R Get Version
Description
Returns the version number of R being used with JMP R interfaces.
R Init( named_arguments )
Description
Initializes the R session.
Returns
0 if the initialization is successful; any nonzero value otherwise.
Argument
Echo(Boolean)
R Is Connected()
Description
Determines whether a connection to R exists.
Returns
1 if connected; 0 otherwise.
Arguments
None.
R JMP Name to R Name( name )
Description
Maps the specified JMP variable name to the corresponding R variable name using R naming rules.
Argument
name
The name of a JMP variable to be sent to R.
Returns
A string that contains the R name.
R Send( name, <R Name( name )>)
Description
Sends named variables from JMP to R.
Returns
0 if the send is successful; any nonzero value otherwise.
Arguments
name
required. The name of a JMP variable to be sent to R.
R Name(name)
(Optional) You can give the variable that you send to R a different name. For example
	R Send(Here:x, R Name("localx"))
For data tables only:
Selected(Boolean)
optional, named, Boolean. Send only selected rows from the referenced data table to R.
Excluded(Boolean)
optional, named, Boolean. Send only excluded rows from the referenced data table to R.
Labeled(Boolean)
optional, named, Boolean. Send only labeled rows from the referenced data table to R.
Hidden(Boolean)
optional, named, Boolean. Send only hidden rows from the referenced data table to R.
Colored(Boolean)
optional, named, Boolean. Send only colored rows from the referenced data table to R.
Markered(Boolean)
optional, named, Boolean. Send only markered rows from the referenced data table to R.
Row States(Boolean, <named arguments>)
optional, named. Includes a Boolean argument and optional named arguments. Send row state information from the referenced data table to R by adding an additional data column named “RowState”. Multiple row states are created by adding together individual settings. The individual values are as follows:
Selected = 1
Excluded = 2
Hidden = 4
Labeled = 8
Colored = 16
Markered = 32
The named arguments for the Row States() argument are as follows:
Colors(Boolean)
optional, named, Boolean. Sends row colors. Adds additional data column named “RowStateColor”.
Markers(Boolean)
optional, named, Boolean. Sends row markers. Adds additional data column named “RowStateMarker”.
Examples
Create a matrix, assign it to X, and send the matrix to R:
X = [1 2 3];
rc = R Send( X );
Open a data table, assign a reference to it (dt), and send the data table, along with its current row states, to R:
rc = R Send( dt, Row States(1) );
R Send File( "pathname", <R Name("name")>)
Description
Sends the specified data file from JMP to R.
Returns
Arguments
pathname
required. A quoted string that contains a pathname for a file.
R Name(name)
(Optional) You can give the data file that you send to R a different name.
R Submit( "rCode", <named_arguments> )
Description
Submits the specified R code to the active global R connection.
Returns
Arguments
rCode
A required, quoted string that contains the R code to submit.
Expand(Boolean)
Echo(Boolean)
Async(Boolean)
An optional, Boolean, named argument. If set to true (1), the submit can be canceled either by pressing the ESCAPE key, or by using this message to an R connection: rconn<<Control( Interrupt( 1 ) ). False (0) is the default value.
Example
rc = R Submit("\[
	x <- rnorm(5)
	print(x)
	y <- rnorm(5)
	print(y)
	z = plot(x, y)
R Submit File( "pathname" )
Description
Submits statements to R using a file pointed in the specified pathname.
Returns
Argument
Pathname
A quoted string that contains the pathname to the file that contains the R code to be executed.
R Term()
Description
Terminates the currently active R integration interface.
Returns
Returns 0 if the termination is successful and -1 otherwise.
Arguments
None
