Scripting Guide > Scripting Platforms > Specify Which Columns to Analyze > Specify Multiple Column Names at Once
发布日期: 04/13/2021
If you have a lot of column names, instead of listing each one individually, you can use lists as column arguments. The following example gets the column names from a list and runs a Distribution on each column in the list.
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
dt << Fit Group( Oneway( Y( {:SO2, :POP} ), X( :State ) ) );
If you do not know the column names when you are writing the script, use column indices, as done in the following example.
dt << Distribution( Y( 1::N Col( dt ) ) );
You can also use indices when specifying effects as shown here:
dt << Fit Model( Y( :y ), Effects( 1 :: 4 ) );
