JSL Syntax Reference > SQL Functions Available for JMP Queries
发布日期: 04/13/2021
The Query() JSL function performs a SQL query on selected tables and exports the data to a data table. The following example first assigns the t1 alias to Big Class.jmp. name, age greater than 13, and height are then selected from the t1 table.
Query( Table( dt, "t1" ),
       "SELECT t1.name, t1.age, t1.height FROM t1
       WHERE t1.age > 13" );
You can use SQL functions in a query. For example, SELECT CURRENT_TIMESTAMP returns the current UTC/GMT time stamp as a SQLite time string:
Query( Scalar, "SELECT CURRENT_TIMESTAMP;" );
This appendix lists the numeric, date-time, string, system SQL, and aggregate functions that you can use in SQL queries. “Yes” in the SQLite column indicates native SQLite functions. See the Online SQLite documentation at https://www.sqlite.org/lang.html.
Contents
Numeric SQL Functions
Date-Time SQL Functions
String SQL Functions
System SQL Functions
Aggregate SQL Functions
