Scripting Guide > Data Structures > Associative Arrays > Work with Associative Arrays
发布日期: 04/13/2021
Find the Number of Keys
To determine the number of keys that an associative array contains, use the N Items() function.
cary = Associative Array();
cary["state"] = "NC";
cary["population"] = 116234;
cary["weather"] = "cloudy";
cary["population"] += 10;
cary["weather"] = "sunny";
cary["high schools"] = {"Cary", "Green Hope", "Panther Creek"};
N Items( cary );
4
Add and Delete Keys and Values
To add or delete key-value pairs from an associative array, use the following functions:
Insert()
Insert Into()
Remove()
Remove From()
Notes:
Insert() and Remove() return a named copy of the given associative array with the key-value pair added or removed.
Insert Into() and Remove From() add or remove the key-value pairs directly from the given associative array.
Insert() and Insert Into() take three arguments: the associative array, a key, and a value.
Remove() and Remove From() take two arguments: the associative array and a key.
If you insert a key with no value provided, the key is assigned a value of 1.
Examples
The following examples illustrate Insert() and Insert Into():
newcary = Insert( cary, "time zone", "Eastern" );
Show( cary, newcary );
cary = ["high schools" => {"Cary", "Green Hope", "Panther Creek"}, "population" => 116244, "state" => "NC", "weather" => "sunny"];
newcary = ["high schools" => {"Cary", "Green Hope", "Panther Creek"}, "population" => 116244, "state" => "NC", "time zone" => "Eastern", "weather" => "sunny"];
Insert Into(cary, "county", "Wake");
Show( cary );
cary = ["county" => "Wake", "high schools" => {"Cary", "Green Hope", "Panther Creek"}, "population" => 116244, "state" => "NC", "weather" => "sunny"];
Note that cary <<Insert is a message sent to an associative array that does the same thing as the function Insert Into(). For example, these two statements are equivalent:
cary << Insert( "county", "Wake" );
Insert Into( cary, "county", "Wake" );
The following examples illustrate Remove() and Remove From():
newcary = Remove( cary, "high schools" );
newcary = ["population" => 116244, "state" => "NC", "weather" => "sunny"];
Remove From( cary, "weather" );
Show( cary );
cary = ["high schools" => {"Cary", "Green Hope", "Panther Creek"}, "population" => 116244, "state" => "NC"];
Note that aa << Remove is a message sent to an associative array that does the same thing as the function Remove From(). For example, these two statements are equivalent:
cary << Remove( "weather" );
Find Keys or Values in an Associative Array
To determine whether a certain key is contained within an associative array, use the Contains() function.
Contains(cary, "high schools");
1
Contains(cary, "lakes");
0
To obtain a list of all keys contained in an associative array, use the << Get Keys message.
cary << Get Keys;
{"high schools", "population", "state", "weather"}
To obtain a list of all values contained in an associative array, use the <<Get Values message.
cary << Get Values;
{{"Cary", "Green Hope", "Panther Creek"}, 116244, "NC", "sunny"}
If you want to see only the values for certain keys, you can specify them as arguments. The keys must be given as a list.
cary << Get Values({"state", "population"});
{"NC", 116244}
To see a value for a single key, use the <<Get Value message. Specify only one key and do not place it in a list.
cary << Get Value("weather");
"sunny"
To obtain a list of all key-value pairs in an associative array, use the <<Get Contents message.
cary << Get Contents;
{{"high schools", {"Cary", "Green Hope", "Panther Creek"}},
{"population", 116244},
{"state", "NC"},
{"weather", "sunny"}}
Note: Using the <<Get Contents message, the returned list does not include the default value. Keys are listed alphabetically.
Iterate through an Associative Array
To iterate through as associative array, use the <<First and <<Next messages. <<First returns the first key in the associative array. <<Next(key) returns the key that follows the key that is given as the argument.
The following example removes all key-value pairs from the associative array cary, leaving an empty associative array:
currentkey = cary << First;
total = N Items( cary );
For( i = 1, i <= total, i++,
	nextkey = cary << Next( currentkey );
	Remove From( cary, currentkey );
	currentkey = nextkey;
Show( cary );
cary = [=>];
