发布日期: 11/15/2021
Draw Arrows
Arrow() draws an arrow from the first point to the second point. The default arrowhead is scaled to 1 plus the square root of the length of the arrow. To set the length of the arrowhead, add an optional first argument, specifying the length of the arrowhead in pixels. The following example draws simple arrows.
win = New Window( "Arrowheads",
	Graph Box(
		Pen Size( 4 );
/* matrix 1 defines the x coordinates of an arrow
matrix 2 defines the y coordinates of an arrow */
		Arrow( 20, [10 30 90], [88 22 44] );
The following example draws arrows in a circular pattern.
win = New Window( "Hurricane",
	Graph Box(
		Frame Size( 100, 100 ),
		X Scale( -100, 100 ),
		Y Scale( -100, 100 ),
		For( r = 35, r < 100, r += 20,
			ainc = 2 * Pi() * 3 / r;
			For( a = 0, a < 2 * Pi(), a += ainc,
				x = r * Cosine( a );
				y = r * Sine( a );
				aa = a + ainc * 45 / r;
				rr = r - r / 6;
				x2 = rr * Cosine( aa );
				y2 = rr * Sine( aa );
/* list 1 defines the start point for the arrow
list 2 defines the end point for the arrow */
				Arrow( {x, y}, {x2, y2} );
Figure 12.11 Drawing Arrows
Drawing Arrows
The following example compares drawing with a specified length (19 pixels) and drawing with the default arrow head size.
	Graph Box(
		Frame Size( 300, 300 ),
		X Scale( 0, 100 ),
		Y Scale( 0, 220 ),
		x = 10;
		y1 = 10;
		y2 = y1 + 10;
		For( i = 1, i < 10, i++,
			Pen Color( "Red" );
			Arrow( {x, y1}, {x, y2} );
			y2 += 10;
			y1 += 100;
			y2 += 100;
			Pen Color( "Blue" );
			Arrow( 20, {x, y1}, {x, y2} );
			x += 10;
			y1 -= 100;
			y2 -= 100;
			Text Color( "Red" );
			Text( {10, 80}, "Without Length Arg" );
			Text Color( "Blue" );
			Text( {10, 200}, "With Length Arg" );
Figure 12.12 Arrowhead Sizes
Arrowhead Sizes
As with Line(), you can either specify the points in two-item lists as demonstrated above or as matrices of x and then y coordinates.
