Scripting Guide > Scripting Tools > Work with the Script Editor > Errors Are Marked by Special Characters
发布日期: 11/15/2021
After you run a script, the /*###*/ characters in the log indicate the location of an error in the script execution. The following example shows a script in which the height column name is misspelled.
Names Default To Here( 1 );
dt:heihgt[3]; // misspelled column name
After you run the script, the log reads:
Scoped data table access requires a data table column or variable in access or evaluation of 'dt:heihgt' , dt:heihgt/*###*/
In the following script, error marked by /*###*/
dt:heihgt/*###*/[3];
/*###*/ directly follows the misspelled height argument.
