Scripting Guide > Extending JMP > Communicate with SAS Cloud Analytic Services > Export Data from a Data Table to a CAS Server
发布日期: 11/15/2021
CAS Export Data() exports a data table to a CAS server to run an action on it.
CAS Export Data(
	Open( "$SAMPLE_DATA/Big Class.jmp" ),
	"casuser",
	"Big Class"
CAS Export Data() also has two arguments:
Save(0) saves the data in memory.
Save(1) saves the data to the file system.
