发布日期: 11/15/2021
Get an API Key
Before you can script reports and publish them to JMP Live, you might need an API key. JMP Live administrators determine whether an API key is required for scripting.
An API key is unique for a user and a JMP Live server. That means that if you obtain a new API key, it overrides the previous one, and any scripts using the previous API key will need to be updated to use the new API key.
To obtain an API key:
1. Log into JMP Live.
2. At the top, click your user icon and select Settings.
3. Click Generate API Key. Make a note of your key.
