发布日期: 11/15/2021
Plot Col Boxes
Plot Col Box<<Get As Matrix
Gets the values in a matrix, specifically a column vector.
Plot Col Box<<Get Labels
Gets the labels for each row.
Plot Col Box<<Remove Element(row number)
Removes an element from the column at the specified position.
Plot Col Box<<Set Labels({list})
Sets the labels for each row.
Plot Col Box<<Set Scale(minimum, maximum, <"format">, <width>, <decimal places>, <"Use Thousands Separator">)
Description
Specifies the minimum and maximum values of the horizontal axis.
Arguments
The format arguments specify a format that is used when the first two arguments are 0 and 1. A number of formats can be set on plot col boxes. See Number Col Box<<Set Format(<width>|<width, decimal places>, <"Use Thousands Separator">) for more information about the syntax.
Plot Col Box<<Set Values([matrix] or {list})
Sets values for the matrix (for numeric variables) or list (for character variables).
