Scripting Guide > Extending JMP > Share Reports on JMP Live > Update Data in JMP Live Reports
发布日期: 11/15/2021
If the data behind a JMP Live report changes, you can update the data and regenerate the report. You can update the data for a standalone report (using the report ID) or for all the reports in a folder (using the folder ID).
The following example updates data for an individual report. Suppose that in the Big Class.jmp data table, a subject’s age changed and you want to update an associated age report on JMP Live.
dt:Age[1] = 77;
/* Use the JMP Live Connection you established to update the data for the report with the specified ID based on the updated Big Class.jmp data table. */
updateresult = liveconnection << Update Data( report << Get ID( ), Data( dt, "Big Class.jmp" ));
// Show the outcome of the update.
show( updateresult << Succeeded );
Similarly, you can also specify the folder that the report resides in:
updateresult = liveconnection << Update Data( folder << Get ID( ), Data( dt, "Big Class.jmp" ));
Only reports in the folder using the specified data table update.
