Scripting Guide > Extending JMP > Share Reports on JMP Live > Work with Other Content in JMP Live Reports
发布日期: 11/15/2021
Primarily in JSL, you work with JMP Live folders and reports. However, you can publish images to JMP Live reports. In JSL, you can use a generic object called a JMP Live Post to manage images or other content that does not fall under reports or folders. See the JMP Live Post function in the JMP Scripting Index at Help > Scripting Index.
