Scripting Guide > Three-Dimensional Scenes > Add Lighting, Materials, and Normal Vectors
发布日期: 09/18/2023
The following JSL methods enable you to add lighting, materials, and normal vectors to your shapes. Using these methods, models can appear shiny or light-absorbing.
Create Light Sources
Specify Lighting Models
Specify Normal Vectors
Set the Shading Model
Set Material Properties
Alpha Blending
Fade Using Fog
Example of Drawing a Spinning Cylinder
