Scripting Guide > Extending JMP > Work with SAS > Create SAS DATA Step Code for Formula Columns
发布日期: 09/18/2023
Sending Get SAS Data Step for Formula Columns to a JMP data table includes column formulas in the SAS data step code. Here is an example that outputs the formula for the Ratio column:
dt << New Column( "Ratio", Formula( :height / :weight ));
dt << Get SAS Data Step for Formula Columns;
This script output the following code to the log:
/*%PRODUCER: JMP - DataTable Formulas */
/*%TARGET: Ratio */
/*%INPUT: height */
/*%INPUT: weight */
/*%OUTPUT: Ratio */
/* Code to score Ratio */
Ratio =height/weight
drop ;
To get formulas for all columns, omit the column names as shown here:
You can also include column formulas in scoring code for SAS Model Manager. Send Get MM SAS Data Step for Formula Columns to the data table.
dt = Open( "$SAMPLE_DATA/Tiretread.jmp" );
dt << Get MM SAS Data Step for Formula Columns;
The results of this script are also shown in the log.
As with Get SAS Data Step for Formula Columns, specifying column names is optional.
