Scripting Guide > Scripting Platforms > Send Messages to a Platform > Interpret the Show Properties List
发布日期: 09/18/2023
Show Properties lists the messages that can be sent to a scriptable JMP object, such as a data table, an analysis platform, or a display, producing a text report in the log. Each type of message is categorized and appears in brackets, and can be any of the following:
Message Type
Description
Example
[Action]
Correspond to options in the JMP interface.
Redo Analysis [Action] (Rerun this same analysis in a new window. The analysis will be different if the data has changed.)
[Action Choice]
[Enum]
List specific choices for their arguments.
Fit Polynomial [Action Choice] {2, quadratic, 3, cubic, 4, quartic, 5, 6}
Draw [Enum] {Filled, Outlined, Filled and Outlined}
[Boolean]
Turn options on or off. Arguments are usually 1 or 0. If a message is specified without an argument, sending the message changes it to the opposite state. [Default On] indicates that the option is on by default.
Show Points [Boolean] [Default On]
[Subtable]
List options within submenus. You use the option itself, not the parent item.
Script [Subtable]
Save Script to Datatable [Action] (Return to the launcher for this analysis.)
[New Entity]
Open a new window in the interface.
Prediction Interval [New Entity] (Prediction Interval to contain a single future observation or the mean of m future observations.)
For example, run the following JSL:
biv = Bivariate( Y( :height ), X( :age ) );
Show Properties( biv );
The object biv supports Subtable, Boolean, Action, and Action Choice type messages. Enum and New Entity messages are not supported.
