发布日期: 09/18/2023
Scatterplot 3D Scripts
If your machine supports acceleration, and you want to display the 3-D scatterplot faster, you can turn on the Use Hardware Acceleration option, or in JSL, specify the Scene3DHardwareAcceleration global variable. A value of 1 turns it on, and a value of zero turns it off.
dt = Open( "$SAMPLE_DATA/Solubility.jmp" );
Scene3DHardwareAcceleration = 1;
dt << Scatterplot 3D(
	Y( :"1-Octanol"n, :Ether, :Chloroform, :Benzene, :Carbon Tetrachloride, :Hexane )
