Scripting Guide > Scripting Platforms > Script-Only Messages and Arguments by Platform > Structural Equation Models Script-Only Messages
发布日期: 09/18/2023
The following messages for a Structural Equation Models object enable you to specify aspects of the model specification, the fitted model, and the path diagram, respectively. These messages are available only in JSL.
structural_equation_models_object << Model Specification( ... );
structural_equation_models_object << Fit( ... );
structural_equation_models_object << Path Diagram Properties( ... );
The following messages are available within a Model Specification() or Fit() message sent to a Structural Equation Models object.
structural_equation_models_object << Fit( Covariances( ... ) );
structural_equation_models_object << Fit( Loadings( ... ) );
structural_equation_models_object << Fit( Means( ... ) );
structural_equation_models_object << Fit( Model Name( string ) );
structural_equation_models_object << Fit( New Latent( string ) );
structural_equation_models_object << Fit( Regressions( ... ) );
structural_equation_models_object << Fit( Variances( ... ) );
The following messages are available within a Path Diagram Properties message sent to a Structural Equation Models object.
SEM_object << Path Diagram Properties( Constant Border Color( string ) );
SEM_object << Path Diagram Properties( Constant Fill Color( string ) );
SEM_object << Path Diagram Properties( Constant Font( font ) );
SEM_object << Path Diagram Properties( Constant Height( number ) );
SEM_object << Path Diagram Properties( Constant Shape( ... ) );
SEM_object << Path Diagram Properties( Constant Size Option( string ) );
SEM_object << Path Diagram Properties( Constant Text Color( string ) );
SEM_object << Path Diagram Properties( Constant Width( number ) );
SEM_object << Path Diagram Properties( Diagram Size( {x, y} ) );
SEM_object << Path Diagram Properties( Latent Border Color( string ) );
SEM_object << Path Diagram Properties( Latent Fill Color( string ) );
SEM_object << Path Diagram Properties( Latent Font( font ) );
SEM_object << Path Diagram Properties( Latent Height( number ) );
SEM_object << Path Diagram Properties( Latent Shape( ... ) );
SEM_object << Path Diagram Properties( Latent Size Option( string ) );
SEM_object << Path Diagram Properties( Latent Text Color( string ) );
SEM_object << Path Diagram Properties( Latent Width( number ) );
SEM_object << Path Diagram Properties( Lock Diagram( 0|1 ) );
SEM_object << Path Diagram Properties( Manifest Border Color( string ) );
SEM_object << Path Diagram Properties( Manifest Fill Color( string ) );
SEM_object << Path Diagram Properties( Manifest Font( font ) );
SEM_object << Path Diagram Properties( Manifest Height( number ) );
SEM_object << Path Diagram Properties( Manifest Shape( ... ) );
SEM_object << Path Diagram Properties( Manifest Size Option( string ) );
SEM_object << Path Diagram Properties( Manifest Text Color( string ) );
SEM_object << Path Diagram Properties( Manifest Width( number ) );
SEM_object << Path Diagram Properties( Path Styles( ... ) );
SEM_object << Path Diagram Properties( Paths Alpha Level( number ) );
SEM_object << Path Diagram Properties( Paths Color( string ) );
SEM_object << Path Diagram Properties( Paths Font( font ) );
SEM_object << Path Diagram Properties( Paths Opacity( number ) );
SEM_object << Path Diagram Properties( Paths Thickness( number ) );
SEM_object << Path Diagram Properties( Place Nodes( ... ) );
SEM_object << Path Diagram Properties( Rotate Loops( ... ) );
