发布日期: 09/18/2023
Tabulate Script-Only Messages
The following messages for a Tabulate object are available only in JSL:
tabulate_object << Add Table( ... );
tabulate_object << Change Item Label( ... );
tabulate_object << Display Column Width( ... );
tabulate_object << Modify Table( ... );
tabulate_object << Order by Count( ... );
tabulate_object << Plot Scale( min, max );
tabulate_object << Remove Column Label( Grouping Columns( column ) );
tabulate_object << Restore Column Label( Grouping Columns( column ) );
tabulate_object << Set Format( ... );
tabulate_object << Test Build( Sample Size( number ) );
tabulate_object << Test Data View;
tabulate_object << Uniform plot scale( 0|1 );
