Scripting Guide > Three-Dimensional Scenes > Draw Text > Use Text with Rotate and Translate
发布日期: 09/18/2023
The following example uses the Text function with the Translate and Rotate messages.
scene = Scene Box( 600, 600 ); // make a scene box...holds an OpenGL scene
New Window( "Example 2", scene ); // put the scene in a window
// the "lens" is 45 degrees, near is 3 units from the camera, far is 7
scene << Perspective( 45, 3, 7 );
// move the world so that 0,0,0 is visible in the camera
scene << Translate( 0.0, 0.0, -4.5 );
// rotate the first text about the Y (vertical on screen) axis
scene << Rotate( 30, 0, 1, 0 );
scene << Color( 1, 0, 2 ); // magenta
scene << Text( "center", "baseline", .2, "Top magenta string" );
// the next string is even farther away from the camera
scene << Translate( 0.0, 0.0, -2.0 );
// rotate the second text about the Y (vertical on screen) axis
scene << Color( 0, 1, 1); // aqua blue
scene << Text( "center", "baseline", .2, "Back aqua blue very long string" );
// update the display box in the window using the current display list
scene << Update;
Figure 13.14 Rotating and Translating Text Strings
Note that the aqua blue string extends backward beyond the far clipping plane. Change the 7 to 10 in the Perspective message to see the complete string.
