Atkinson, A. C., and Donev, A. N.(1992). Optimum Experimental Designs. New York: Oxford University Press.
Box, G. E. P., and Draper, N. R. (1987).Empirical Model–Building and Response Surfaces. New York: John Wiley & Sons.
Box, G. E. P., Hunter,W. G., and Hunter, J. S (1978).Statistics for Experimenters. New York: John Wiley & Sons.
Box, G. E. P., Hunter,W. G., and Hunter, J. S (2005).Statistics for Experimenters: Design, Innovation, and Discovery. 2nd ed. New York: John Wiley & Sons.
Cochran, W. G., and Cox, G. M. (1957).Experimental Designs. 2nd ed. New York: John Wiley & Sons.
Colbourn, C., and Dinitz, J., eds. (2010).Handbook of Combinatorial Designs. 2nd ed. Boca Raton, FL: CRC Press.
Cornell, J. A (1990).Experiments with Mixtures. 2nd ed. New York: John Wiley & Sons.
DuMouchel, W., and Jones, B. (1994).“A Simple Bayesian Modification of D-Optimal Designs to Reduce Dependence on an Assumed Model.” Technometrics 36:37–47.
Fries, A., and Hunter, W. G. (1984).“Minimum Aberration 2k-p Designs.” Technometrics 22:601-608.
Goos, P. (2002).The Optimal Design of Blocked and Split Plot Experiments. New York: Springer.
Goos, P., and Jones, B. (2011).Optimal Design of Experiments: A Case Study Approach. New York: John Wiley & Sons.
Jones, B. (1991).“An Interactive Graph For Exploring Multidimensional Response Surfaces.” In Proceedings of the Annual Joint Statistical Meetings of the American Statistical Association. Alexandria. VA: American Statistical Association.
Jones, B., and Nachtsheim, C. J. (2011a). “A Class of Three-Level Designs for Definitive Screening in the Presence of Second-Order Effects.” Journal of Quality Technology 43:1-15. http://www.jmp.com/en_us/whitepapers/jmp/class-three-level-definitive-screening.html. Retrieved January 23, 2017.
Montgomery, D. C. (2013).Design and Analysis of Experiments. 8th ed. New York: John Wiley & Sons.
Morgan, J. (2009). “Constrained Covering Arrays: Resolving Invalid Level Combination Constraints.” Technical Report, Cary NC: SAS Institute Inc., also in Supplemental Proceedings of the 20th International Symposium on Software Reliability Engineering.
Morgan, J. (2014).“Computing Coverage and Diversity Metrics for Constrained Covering Arrays,” Technical Report, Cary NC: SAS Institute Inc.
Myers, R. H., Montgomery, D. C., and Anderson-Cook, C. M. (2009). Response Surface Methodology, Process and Product Optimization Using Designed Experiments. 3rd ed. New York: John Wiley & Sons.
Worley, B. A (1987).Deterministic Uncertainty Analysis. Technical Report ORN-0628, Oak Ridge National Laboratory.
Wu, C. F. J., and Hamada, M. S (2009). Experiments: Planning, Analysis, and Optimization. 2nd ed. New York: John Wiley & Sons.
Zhang, Z., and Zhang, J. (2011).“Characterizing Failure-Causing Parameter Interactions by Adaptive Testing.” In Proceedings of the 2011 International Symposium on Software Testing and Analysis, 331-341.
