If you want to lock a variable to prevent it from being changed, use the Lock Symbols() function. (Lock Globals() is an alias.)
To release the lock and enable the global to be changed, use the Unlock Symbols() function. (Unlock Globals() is an alias.)
注意:You cannot use Lock Symbols() to lock a namespace. Instead, use ns << Lock Namespace.
