The Summation() function adds the body results over all i values. The syntax is:
s = Summation( i = 1, 10, i );
Sets the s variable to the value of the function.
Begins the Summation() loop.
Sets i to 1.
All values of i from 1 to 10 are added together, resulting in 55.
This behavior is similar to Σ in the Formula Editor. The following expression:
