The Choose() function shortens scripts even more than Match(), provided the arguments are tested against integers. The syntax is:
Suppose you have a data table with a group column of numeric values from 1 through 7. If the first cell contains the number 1, the following script returns x = "Low".
Creates the x variable.
Begins the Choose() loop.
Evaluates the value of group in the first row.
If the value of group is 1, return "Low".
If the value of group is 2, return "Medium".
If the value of group is 3, return "High".
Closes the x variable.
