Journals that are created in JMP 14 or later might contain compressed matrix data for large matrices. If you have JSL scripts that open journals and extract data from them, you might need to use the Get Journal message (which does not compress the matrices) rather than saving the journal to disk with the Save Journal message.
In JMP 13, if you pass Tab Page Box() to Tab Box<<Add, <<Append, <<Insert, or <<Replace, the result is Tab Page Box() contained with a Tab Page Box(), because these functions wrap the provided content.
If the Allow Boolean and Null Constraints preference has been turned on in a script, you cannot use true, false, and null as variable names.
The Normal Mixtures message no longer works in K Means Cluster scripts now that K Means has been separated from Normal Mixtures.
The Weighting() and Centering and Scaling() arguments for an SVD analysis in Text Explorer are now required. To avoid having a Specifications window appear, update Text Explorer scripts to include Weighting() and Centering and Scaling() arguments in the Latent Semantic Analysis() argument. The Maximum Number of Terms() and Minimum Term Frequency() arguments are also required to avoid the Specifications window.
Maximum() and Minimum() no longer work on a list of strings. As an additional note, Maximum() and Minimum() for strings never actually worked. It returned the last one in the list.
To add a transform column to a custom display box, use Filter Col Selector() instead of Col List Box(). You also don’t need to use Column Reference.
A tree box Set Node Select Script message might need special attention if the JSL will run on both Windows and Macintosh. In a nested tree with a child selected under a collapsed parent node, the script will not be called on Windows and will be called twice on Macintosh.
