biv = dt << Bivariate( X( dt:weight ), Y( dt:height ), By( dt:age ) );
biv << Fit Line; // sends the Fit Line message to
Suppose that you have a list of three control charts and you send a message (such as Save Interactive HTML) to the list. The message is sent to each member of the list in turn. First, it saves an HTML page with the first control chart; then it saves a second HTML page with the same name that contains the second control chart; and then it saves a third HTML page with the same name that contains only the third control chart. You end up with a page that contains only the third control chart.
Top Parent treats the first object as the single container:
