New Table( "My Table" );
The following sections describe the optional arguments for the New Table() function.
The optional visibility argument specifies whether the new data table is shown. visibility( "invisible" ) hides the data table from view; it appears only in the JMP Home Window and the Window menu. visibility( "private" ) avoids opening the data table. visibility( "visible" ) shows the data table. "visible" is the default value.
Private tables are not counted when N Table() returns the number of open data tables.
Private tables cannot be made current with Current Data Table().
An optional argument that can define the new table. For example, the following script creates a new data table named Little Class. It adds three rows and two named columns as well as entering values for each cell in the table:
