Assign rbiv to the report layer:
rbiv = biv << Report;
Show Properties( rbiv ); // show the properties of the report
注意:The log lists the messages to use with reports. Using Show Properties() is an alternative to the Scripting Index.
Close() is a Boolean function (true or false), and passing 0 indicates that the outline is not closed.
rbiv["Polynomial Fit Degree=4", "Parameter ?", Column Box( "Estimate" )] << Select; // dig down in the outline tree
rbiv << Deselect;
The first argument to Set Format sets the column width by the number of characters to display. The second argument sets how many decimal places are shown in the table.
Try(
estimate = ests << Get( i );
Show( estimate );
10.
Use a For() loop to count down to the row for the term that you want. The second argument to For() is a condition; as long as the condition tests true, looping continues. Here the test is “when the string in the Terms column is not "^3" and we have not reached the tenth row.” As soon as the string does match, looping stops and i’s value is the number for the matching row. You then use i as a subscript to the Get message on the Estimates column.
