JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Scripting Tools
Working with the Log
• Show the Log in the Script Window
上一个
下一个
You can view the log inside the script window by right-clicking and selecting
Show Embedded Log
. This option makes it easy to edit and run a script, quickly see the results of your changes, and then continue to develop the script.
The embedded log always appears in the Scripting Index script window but is not available in Application Builder and the Debugger.
