These settings are stored in a file named JMP.jdeb, the location of which is defined in the USER_APPDATA variable:
Windows 7 and higher: "/C:/Users/<username>/AppData/Roaming/SAS/JMP/14/"
Macintosh: "/Users/<username>/Library/Application Support/JMP/14/"
注意:On Windows, the paths differ based on the JMP edition. In JMP Pro, the path refers to “JMPPro”. In JMP Shrinkwrap, the path refers to “JMPSW”.
