JMP 14.2 联机文档
发现 JMP
使用 JMP
基本分析
基本绘图
刻画器指南
实验设计指南
拟合线性模型
预测和专业建模
多元方法
质量和过程方法
可靠性和生存方法
消费者研究
Scripting Guide
JSL Syntax Reference
该帮助的版本不再更新,请参见
获取最新的版本.
Scripting Guide
Extending JMP
Working with SAS
• Get the Values of SAS Macro Variables
上一个
下一个
JMP provides several methods for querying SAS macro variables.
To show the
systime
value:
systime = sas << Get Macro Var("SYSTIME");
show(systime);
To show the defined SAS macro variables:
macro_names = sas << Get Macro Var Names();
show(macro_names);
To iterate through the SAS macro variables and print out the values:
For( i = 1, i <= N Items( macro_names ), i++,
macro_value = sas << Get Macro Var( macro_names[i] );
output = macro_names[i] || " " || Char( macro_value );
Show( output );
To submit SAS code that defines “test” as a SAS macro variable and then gets the value from SAS:
sas << Submit( "%let test = 1;" );
test = sas << Get Macro Var( "test" );
Show( test );
All macro variable values will evaluate to numbers, if possible, otherwise they will be characters.
